hi there, how can i update to the latest rhino plugin in order to be able to export/import rhino geometry ?! I downloaded the latest plugin and now i have both on the toolbar and the newst doesnt export anything, so short said ... doesnt work
this kinda happens sometimes, what you should do is, first, remove any installer and use download button so you could download the latest version, then, install it and it usually should show it in Rhino, but if it doesn’t, right click on top toolbar, choose show toolbar, then look for “D5 Live Sync” and chick it. also uncheck “D5 convertor”.
Hi there. You may want to try @DynamicRenderLabs’ suggestion and see if it solves the issue. Otherwise, you may update us here so we can further assist you. Thank you.
hi there, yes it worked well, after uninstall the old one and installing the new, was everything just fine. many thx
