Help, texture not aligned
**D5 Render Version: 2.5
**Graphics Card: RTX 3070
**Driver Version:
**Issue Description: As seen at the screenshot, my texture is not aligned. The source is a ArchiCAD model, where walls and ceilings are linked. How can one fix this issue?
The issue also is, that I can’t edit the texture sepperatly for each component…
Hi apothem.riff_0u
You can do it from archicad, if the wall is unique with the roof cut, you can add a texture of rustic wood slats from archicad surfaces, you won’t have this problem, so you sync it, that’s it.
I hope I have helped you
I have solved it by changing the material template in D5 to Custom and enabling Triplanar…
Hi mate, thanks for the update, are you sure this face is flat or not divided into 3 parts? Can you send this face to us for testing? we will find the potential bug, thanks a lot.
support@d5techs.com
