I am having trouble with the new grass material, I am using the first template but whenever I render
the scene from a distance there seams to be a limit where the grass is shown, after a certain radius the grass is not visible anymore. Is there any way I can overcome this issue ?
Hi! @kreativstudio
You mean when you render a video, the grass material you applied with the first template will disappear gradually when the camera is getting away from the grassland, am I right?
If yes, please turn off LOD and render a new video again. This feature aims to save GPU usage and let D5 Render load large scene files. So when it is on, the grass far away will seem to disappear.
Hello, thank you for your reply.
Actually I get this issue when rendering a still image not while rendering a video. The two images I have provided are actualy still images. The grass after a certain radius is not visible anymore…
Good day! We have reproduced this issue. The reason why you cannot see the first grass template when you move the camera far away is that there Is something wrong with the culling distance for only the first template. We are working on this issue and later I will give you a new file to solve this issue.
Sorry for your issue. Could you use your D5 normally now? If your D5 is currently not working, it is recommended to uninstall and reinstall D5.
The solution you referenced previously was a previous solution for an older version of D5. Currently it is recommended that you open the preferences and adjust the parameters for the dull distance.
Please contact me if the above tips cannot solve your problem.
Hi, I have turned off Level of Detail. Cull distance is set to 1000m. I chandes grass material to Grass template 3. Yet the problem persists. Grass is not visible in top view render. Are there any further steps to make to avoid this issue?
Can you please include an image? It might also be possible for us to request your D5 file once we confirm the full context of this issue through the attached image that you will be sending.
