Is the NVIDIA RTX 3500 ada graphics card NVIDIA compatible with D5?
Thanks, best regards,
Dimitry
Dimitry
I think this card is quite new I will talk about it with our team. I think you can use the system info to test, if you can pass the test, it would be no problem for you to use D5.
It’s for an ocnfiguration. Thanks for your feedback.
I think you can use the benchmark to test your device D5 Render. Actually, I think your device can support the use of D5.
