Hello.
I’m looking to purchase a graphic card for d5render. This is the model I have found:
I’m wondering if you think this card is good to use the program for an interior studio?
Hello.
Hello petersueco
This board is the minimum requirement for D5 to work. If you’re going to buy one, it would be a good idea to go for a more powerful one, otherwise it will be very slow to work with D5.
Regards
Hi @petersueco
You can run D5 Render with a GTX 1060. It is one of the GPUs that falls under our minimum system requirements. Keep in mind that for optimal performance, we recommend higher-spec GPUs. You may visit our User Self Test Data and see different GPU specifications and how well they work with D5 Render.
