Greetings,
As in attached pictures - the Google Earth images has been completely distorted after opening in D5 Render.
Any solution?
Thank you in advance
Greetings,
Any solution?
May I know which resolution did you choose? 2k?
Hullo,
The image comes from Google Earth max resolution - 4000 x 2517.
Only D5 Render see it this way.
Twinmotion, Lumion, Vray, Thea do not have any problems.
Did you use it as HDR?
May I have the original image? We’d test it and reproduce the issue on our computer to figure out the reason.
Thank you
Did you check the box in the UV scale for Triplaner?
Hullo, thank you.
Alas, no difference except 90 deg strip rotation - attached-please-find images (before-after)
Hi there,
Please make adjustment on UV in sketchUp,increase the UV scale
Hullo,
No effects at all, alas.
Still no solution.
