D5 Render Version :2.8
Graphics Card:quadro rtx 5000
Driver Version:31.0.15.5186
Issue Description:ghost grass object with no selectable elemnt
Steps to Reproduce (optional):scene has 7 different cameras and fbx-max scene links. restarted by selecting all links ghost gets away. but after importing everything back and opening d5 after restart ghost grass is back
Hello @amasood,
Thanks for reaching out.
Just for confirmation, how many layers do you have in this scene? Which layer is this ghost grass located in?
Terrain grass should exist attached to the model, and its display and hiding would follow the model, not having its own separate place in the ‘‘Oblect list’’. Are you meaning that after having hidden its main model, this piece of terrain grass is not hidden along with it, right?
Please also check if the ghost grass is based on this model file.
Default Layer + 3 Landscape layers
Ghost is in the Default Layer
when unlock and delete all, sometime few fbx objects ghost grass goes away.
i have uninstalled live sync and reverted to 3dsmax sync.
there are other errors but ghost grass is not appearing any more
thanks for the updates.
Was the ghost grass located in fbx file?
If it’s convenient for you, you can send the scene file to us (support@d5techs.com, please attach a link to this post in the email). We will check and test it in our environment. If you have any other questions, please let us know.
Cheers
