geo and sky :
-the sky color in Geo and sky is too blue, we need more control on this color like a color correction panel it will help to make the geo and sky usable, I’m totally depending on HDRi skies as the standard sky system looks so unrealistic with the over saturated sky in addition to the weird night time sky everything turns black no ambient effect or moonlight, stars its just very dark and unusable in professional work.
HDRi :
-HDRipreview in the renders is very low res. we need an option to allow a higher resolution texture in the view port, in addition to vertical rotation feature.
-thank for support.
Thanks for your suggestion, I have shared it with the team. ![]()
The saturation of the GEO&Sky can easily be modifiy in post, but the low res HDRI’s is a pain… We discuss that a lot with @Oliver.J so Hopefully we’ll have this fix soon
Thanks guys!
Yeah mate, the low quality in the preview mode is to save resources usage
we may optimize it in future when we have better solutions.
Hi oliver, ![]()
The issue i’m talking isn’t the low quality in preview, wich is a great feature to save ressources!
The problem is the quality when rendered, even with a 16k. its actually ok but it still blurry compare to the render itself, hard to use it for a professional images, even if it creates a nice lighting and atmosphere to the scene.
The output is still limitated to 16k or we can use HDRI up to 24k to have sharper background and sky?
Ok, thanks, we will take it into consideration.
