I have two simple models that will not load in D5. One is FBX and the other made in Sketchup. The file has been at 0% for the last hour and I have tried loading several times. These modesl load into Lumion just fine in seconds.
I have a i9-9900k intel coffee lake chip
nvidia Geforce 2080i RTX
32 Gb Ram
Hi, Im having similar issues the drs file for projects will not load it goes blank at 5% or at 98%. The models loaded previously with no issues. Please help.
Sorry for the inconvenience caused by the problem. Could you send the drs file to our support team for tests? ziyin.zhu@d5techs.com
And I am glad to follow up on this for you. Also it would be good if you could share with us your hardware info and D5 version.
Hi Navs23, I have downloaded your file and done some tests on it. Unfortunately I could not repro the issue you met, but the loading process did get stuck in 5% for a few minutes. I think you may need to check whether the pc is out of RAM when loading the file.(Try restarting your pc and don’t open other high RAM-use programs.) I tested in version 180,181,190 and all are fine, with RTX 2080Ti, 8G
It always gets stuck at %5 and does not load even if I wait for more than 15 minutes.
I tried @Jessie_Huang solution but it didn’t help. There are no problems at creating the file for the first time. Rather having problems when re-loading the same model on another day after a PC shutdown period.
Edit: Solved it. I saw another helpful reply to change the file directory and name %100 english character. It’s solved! Great. Sorry for the inconvineance
