Export scene from a d5 file to another d5 file?
**D5 Render Version: 4.1 **
Graphics Card: RTX 3080
Hello, is there an option to export scene parameters (same point of view, environnement) from a d5 file to another d5 file?
That will be wonderful! Thks :slight_smile:
Hello, we currently do not support exporting scene parameters, but we will consider adding this feature.
As a workaround, you can try making a copy of file then delete all models, keeping only the scene parameters, and save it as a template; also, you can try the Project Merge widget.
