Hola, después de trabajar un buen tiempo en una escena, comenzó a fallar un material emivo, por favor ayuda con la solución. Adjunto renders.
D5 Render Version:
Graphics Card:
Driver Version:
Issue Description:
Hi @mariozippa,
Is this a problem with both preview and output? Have you adjusted the value of bloom of the stripe light? Try to reduce it a bit.
If it’s convenient, can you send the scene file (The entire folder where the .drs file is located) to me directly or to support@d5techs.com ? We can check it for you.
