Hello, if I upgrade my SSD while using an educational license, will it still be valid?
best regards,
ken
best regards,
ken
halo,
The effective period after successful application for the education version is 180 days. To ensure the security of your personal information, it is not possible to replace bound devices (including replacing internal hardware); If you change your device, it will prevent you from logging into the education version account, and we cannot unbind it for you.
Therefore, if you need to replace the device, it is recommended that you reapply after the existing binding period expires.
Thank you again for your understanding and support!
friendly,
chanlee
Hello, if you change the hardware of your device, this may cause your educational licence to be unavailable. It is recommended that you can wait until your licence expires before replacing the hardware and then bind a new educational licence.
Thank you!
I also want to ask , If I wasn’t able to bind my edu license, what will happen?
Will I still be able to apply another edu license?
Because I m planning not to bind my the license, still waiting for my ssd. Then only will I only bind my license, however when that time comes, it already surpass the (When to bind the device: within 7 days after the application is approved) stated in the site.
Thank you!
hi,
You can follow the steps to apply for the license after the binding period, which will not affect your future use of the EDU version of D5.
You can leave your licence unbound for now. After you receive your new ssd and your licence expires, you can apply for a new one again. Hope this helps you.
