I have a strange view in D5 render after exporting true the revit exporter. Moving towards the object takes ages. It happens with all files exporting from revit.
Please help
Please help
Hello, are you using exported d5a or the sync function? You can try to close view sync and restart it, which’ll probably solve the issue.
Thanks for the quick reply!
Yes, I used the sync option in Revit and |I get a distorted model.
When I use the export to a d5a file it worked fine. So will the exporter be updated?
