Al iniciar el programa se cierrra inesperadamente luego de cargar al 99%. Alguien podria saber a que se debe? ya actualice todos los controladores.
I apologize for the inconvenience. Please confirm if:
- Does this occur to all of your files? Or only to specific files?
- Were you able to use D5 Render before? Or is this your first time installing it?
Please also send the following information:
- System Information
- VRAM
- Memory Speed
Que tal! Asi es, sucede desde un archivo simple hasta los mas complejos.Tambien sucede cuando quiero iniciar uno desde 0. Hace tiempo uso este software y solo paso luego de la ultima actualizacion…
Te dejo la informacion solicitada…
Gracias!
We recently posted a thread about AMD GPU Issues with specific Driver Version, please try to check the suggested solution in this post:
Additionally,
- Have you tried reverting to 2.10.2 or the previous version just to check if D5 works normally?
- Please check if you have enabled GPU Scheduling; If yes, disable it.
If the issue persists, please let me know. I may need to collect your log files and video recording.
- Log Files
