D5 UI screen artifacts when importing some library assets
3.0.1.0683:
NVIDIA GeForce RTX 5080 Laptop GPU:
32.0.15.7324:
When I import the basketball or badminton court to the scene, it blacks out and shows some streaks/colored artifacts
Hi @ak.archikraft
I tested the asset on my end and was able to use it successfully without encountering the issue. Could you please try importing the badminton court into an empty scene (without the other models) and check if the problem still occurs?
It’s possible that the issue is related to a conflict with the imported .3dm model in the scene.
Thanks in advance and I look forward to your update.
Hello Ela. I still have the Neon glitch issue. I realized it disappears when I switch turn off the imported model in the object list, and it reappears when I turn it on.
I need help please
Hi @ak.archikraft
I’m sorry to hear about this. Please collect your log files and send them to support@d5techs.com. When you do, make sure to tag me in the email and include the link to this forum post for reference.
Also, may I know if there are other assets causing the same issue, or just the badminton court asset? Thank you
