Hello,
I noticed a malfunction that I wanted to report. I have been using the D5 render software for 2 years for my photo-realistic renderings in my various projects.
For the last 6 months or so I’ve noticed a serious lag in D5 if several Sketchup windows are open at the same time (even if they’re empty). When 1 Sketchup window is open, D5 works perfectly. When 2 Sketchup windows are open, D5 starts to slow down. When 3 or more windows are open, D5 becomes almost impracticable. If there are more than 3, D5 can no longer be used correctly.
My resources are sufficient (64 GB RAM, RTX4070, i7 13700H) and this problem didn’t exist for me before.
It would be good to see how to solve this problem and perhaps contact Sketchup directly.
Wishing you a very good day,
I’m experiencing a jerking that I’ve never had before.
All motion controls, for example, zoom, sliding movements as well as switching scenes in Sketchup with synchronization work smoothly and great.
However, if I zoom, sliding movements as well as switching scenes directly in the D5, it jerks extremely.
Before, my resources were sufficient up to version D5 2.8. (Laptop 2022 with 64 GB RAM, RTX2070, i7-9750 CPU@2.60GHz)
Now it’s very difficult to edit in the D5.
However, after 2 years, I won’t buy a new laptop.
Happy holidays
I apologize for the inconvenience this issue has caused. Which SketchUp Version are you using? Which Live-sync version (Please also share a screenshot for your live-sync version)?
Please send us the following information, while opening these files where the problem was evident (especially for VRAM Usage).
System Information
VRAM
Memory Speed
As for @dadi, does the “jerking” occur in all files or is it file-specific? It would also be best if you also include a screen recording of it.
Thank you.
Hi there,
May I know if were there any specific steps that I missed? I tried to recreate the issue on my end by following your instructions. I have only live-synced one SketchUp file and proceeded to open 2 empty SketchUp files.
- Which SketchUp Version are you using?
- Did you perhaps live-synced the 3 files?
I forget that I have already mentioned this problem not solved in previous post with all the details. I invite you to visit this page containing all the informations,
D5 laggy, help please.
Hi there,
I was able to go over the similar/related issue that you have experienced before, and I do have several questions to ask. Also, It seems that this issue persists only in your PC Environment considering that you have tested it using another device.
As you have mentioned before, you were able to the root cause of this issue which is related to your installed SketchUp Plug-ins.
What are those plug-ins that caused this issue?
Did the issue persist after some time? Considering that it has already been resolved before?
Are you using Studio Driver or Game Ready Driver? You may want to test if switching to Game Ready Driver will help and see if there are any differences.
You can try to reinstall D5 Render at this point considering the instability and issues that you have experienced on your end. I do recommend reinstalling in this method: Please delete these 3 folders first then proceed to reinstall D5 Render.
Another thing to reinstall is your D5 Lives-sync Plug-in, delete this folder first then reinstall the plug-in
Hi there,
Thanks a lot for your answer and treatment.
I will manage to re-install properly D5 render and will advise when done of the result that will certainly solve the issue.
Merry Christmas
Hi @Clov , I did the re-install of D5 as mentionned but did not solve the problem.
Without any synchronisation, I start opening a D5 project I have (+/- simple) with 4 different Sketchup files open. Result is the same, 4 active sketchup files result to an unpracticable D5. I close 1, D5 react better but still not good, then I close a 2de one, D5 better but not fluent … and when I finish with only 1 Sketchup file open, D5 works perfectly.
Please note that I made this test with Studio and GameReady Nvidia last drivers.
Thanks in advance for your help
Hi there,
Thank you for these updates. May I know your VRAM Statistics if you are opening these 4 SketchUp Files? You may use GPU-Z for more accurate results. We also request and suggest that you to screen-record the whole process and send the video to us either by link or private message.
It is also worth knowing that opening 4 SketchUp files will surely have a greater VRAM Consumption and on top of that opening D5 Render. If these 4 SKP files being simultaneously opened is essential to your workflow, I suggest importing the other files as .d5a (if it is possible for you). Looking forward to your response, thank you.
Hi there,
I just send you a private message with elements requested.
thank you
Workaround:
It is expected for FPS to decrease and resource usage to increase when multiple model files are open simultaneously. Running several model files in real-time consumes significant resources, so experiencing some lag is within expectations. We recommend avoiding the simultaneous opening of multiple model files with real-time sync activated. You may consider switching to single-send mode.
- If there are any issues experienced despite optimizing the file and following the recommended workflow, please don’t hesitate to contact us. Thank you
I repeat that I do not activate real-time sync
The problem come from other part
Good news, I found the origin of the problem, so I share:
Issue with Sketchup not starting due to a windows update:
Crash #587744
We are investigating a recent Windows update for incompatible with the new SketchUp Graphics Engine. While we investigate, we recommend reverting to the Classic Graphics Engine.
This can be done in SketchUp by going to Window > Preferences > Graphics > Graphics Engine.
If you are unable to launch SketchUp to make this change, you can use the linked tool below to automatically update your preferences.
1) Close out of all instances of SketchUp and LayOut. If SketchUp is running this will not work.
2) Download the zip file below and extract the Classic engine.bat file.
3) Right click on the file and choose “Run as Administrator”. This will automatically update the SketchUp preferences to use the Classic Engine.
Classic engine.zip - Google Drive
If you need assistance with the steps above or continue to experience crashing please reach out to our support staff at: https://help.sketchup.com/en/contact-support/technical-question/form
Then I inform Sketchup technical service as I do here with my “frenglish” :):
“Hi,
Very interesting, thanks to this issue with a windows update I could find the origine of a problem I have for more than 6 months using D5 render for my finals renders project, used with my Sketchup studio license.
To resume, for 6 months now I was oblige to work with only 1 sketchup window open (more sketchup windows opened influence to D5 render who start not working properly and became unpraticable).
So with this issue, Sketchup did not start, I execute the classic engine.bat, Sketchup re-works.
I directly did a test with 3 sketchup files open and D5 render active, all was working perfectly as in the past (D5 fluent and workable).
So maybe something to take into account to find the origine of this problem.
I share the same message with D5 team,
Have a nice week-end”
Hi there @Thiass
Thank you so much for updating us regarding this issue. After reading your email to the SketchUp Support team Im quite unsure if the issue persists even after you did the suggested solution. So, I just want to confirm if the solutions provided by the SketchUp Support Team were able to resolve the issue that you were experiencing. Or were there no changes despite it?
Additionally, do your colleagues also use SketchUp 2024 or lower versions? Since the issue did not persist on their end.
Let me know, thank you.
Yes it solves the issue, not activating Sketchup graphic engine but staying with classic solve the issue.
Regards
Hi there,
Thank you so much for sharing the full information regarding this issue. I will also report this to my team and see what we can improve on the workflow. ![]()
