Did that, rebooted, same issue. D5 opens & closes.
What’s ridiculous is that it did work on this system, when I first started it.
Rather than blindly trying to change drivers, etc - is there any way to log what actually happens, what’s the error or condition that forces the program to close?
Yes, I’m using the latest version. Here’s the zipped log file (by the way, I E-mailed it to you previously, never got a reply, so trying it here as an attachment).
Hi Carmonaluxury
Sorry for intervening, I’m a colleague, maybe there’s nothing serious about your PC, I read the discussion with the D5 staff. I don’t know any more than them. But I’ll give you an intuition that may solve the problem, you have both window and paid antiviruses, see if in those antiviruses they somehow block the D5 activation, you have to find a file of the program in quarantine and click on it above and make sure that the antivirus does not block it for you.
Maybe this is what doesn’t make the program move forward, if it’s not this I hope you solve it as soon as possible together with the D5 staff, who are fantastic, you need to have a little patience. Come on courage
Hi carmonaluxuru
Sorry for the inconvenience, I read what happened, but I didn’t want to make you uninstall the antivirus, but go into quarantine, especially the Defender one, find a D5 file, you can see this from the path, which goes directly into the D5 folder of the program that is blocking it , you just had to find this file, click on it and have it activated, if this was there. If, however, there is nothing of this kind in quarantine, then it is another type of problem. What you did didn’t give any results, in fact you said that Fuscion maybe wasn’t working. I did a search based on the message you posted, maybe it helps you understand what could have happened:
This, again to understand the problem, perhaps those of the D5 staff will understand more than me
Good luck, Strength is courage
