I’m having an issue with the Rhino Sync feature in D5 Render.
I have the latest versions of D5 Render, Rhino, and the D5 Sync plugin installed. I’ve already tried uninstalling and reinstalling the plugin several times, and I’ve also tested different plugin versions, but the Sync function still doesn’t work.
The plugin appears to be installed correctly, but D5 is not syncing with Rhino.
Could you please advise on what I should check or how to troubleshoot this issue?
I’m facing a similar issue. It does sync but when I make modifications on rhino, it suddenly stops mid work. I have to re-export and then re-sync. Even with this step it doesn’t always work.
