D5 Render is wavy / distorted / overly sharp / overly pixelated” effect, any solution please?
D5 version 2.11.1.
NVIDIA Geforce RTX 4090 24GB
Driver Version 32.0.15.6094
Hi @hamid.hussain
Does this issue appear in the viewport preview as well? Or does it only show in the final rendered image?
Could you let us know your current render settings, like resolution, render quality, and any effects (Depth of Field, Super Resolution, etc.) you’re using? Also, if D5 Super Resolution is turned on, try turning it off — you can find it under Menu → Preferences → Widget.
Let us know if this works out for you. Thanks!
Many thanks. it works. SR was on . finally i can turned this off. thanks team
You’re welcome!
