Notes:
1.Files that have been saved by 2.6 ‘Save Compressed Project’ function cannot be opened while use 2.5 Version.
2.D5 version 2.6 is compatible with any version of D5 Converter;
3.D5 2.5 version supports SU real-time-1.1.0.0033 version(not support export part of the group)
Support 3ds Max plug version 3.4.0.0030 (non-Realtime), do not support 3ds Max plug version1.1.0.0056 (real-time)
4.When you open the 2.5 Version, there will be an update pop-up window, if you need to continue to use version 2.5, please click ‘Cancel Update’.
Suggestion:
You can install both 2.5 and 2.6 on your device under different paths, and both versions can be used separately.
