**D5 Render Version:**2.10.1.0579
**Graphics Card:**NVIDIA geforce RTX 4050 Laptop GPU
**Driver Version:**32.0.15.7283
**Issue Description:**everytime i open D5 render after starting it crashes and shows this message zziplog.zip (671.2 KB)
I apologize for the inconvenience. May I know which specific Laptop Model you are using?
For optimal D5 Render performance on HP Omen/Victus laptops, ensure ‘Discrete’ GPU mode is selected in ‘OMEN Gaming Hub-Graphics Switcher’. This prevents D5 from using the integrated graphics, which it doesn’t support, and avoids abnormal usage.
If you’re not an HP Omen or HP Victus user, then you can try to select 'NVIDIA GPU only ’ in NVIDIA Control Panel - 3D Settings - Manage Display Mode. If there is no such option, try disabling the integrated graphics card.
Which Windows System Version are you using? If you’re using 24H2 you can try to revert back to its previous version and see if there are any differences.
