Memory Speed - Is there a possibility for you to change your Memory Speed? It seems that it’s quite high and we suggest users keep it around 4000 Mhz or below.
If the problem only exists with the current project or some of the scene files, it is likely that the file is too heavy and is taking up too much video memory, exceeding the load of your current device, and you need to lighten and optimize your file.
When used without proper organization by layers or groups these assets could increase VRAM / GPU consumption leading to crashes and error prompts.
CURRENT ISSUE
There is a known issue where some old archives opened in version 2.9 experience excessive resource consumption. This will be addressed in the 2.10 Release. In the meantime, please check your scene files for the following:
Are there a lot of ‘procedurally-generated vine assets’?
Is the drop feature for vegetation paths used?
If so, please optimize your archive accordingly.
If the file fails to open, please delete the ‘f2’ folder under your WorkSpace path and then reopen the archive. Once it’s open, refrain from updating the assets until you have lightened your scene file by deleting some assets, including procedurally generated vines. This will help prevent it from crashing again due to excessive video memory usage.
