D5 Render Version:
**Graphics Card:**geforce rtx 2060 Driver Version:
**Issue Description:**Hello after syncing my rhino file to d5 my d5 file doesnt work and the startup file is 0KB when i open the file, nothing is inside, .This is second time that is happeng, can you help me pls i can sent file and whatever is needed
At last, please send the scene file as well as two folders that contain logs, to ziyin.zhu@d5techs.com. We will try our best to help you find the issue cause and recover the file.
A folder called logs, in the installation directory of D5 2.1
A folder called Saved, in C:/Users/your account/AppData/local/d5_immerse
To confirm, the rhino file caused this problem the first time you synced it, or it was successfully synced once before?
Any updates would be appreciated.
Hello Oliver thanks for the answer . i can the logs right now , but thge scene file is 20 gb . do you want me to sent it that big?
yes it was successfully linked before
Hello nicho, since this file is very big, we may need you to recover the file via autosave backups. Do you have backup files? Please check the private message I send you.
