message says video driver crashed. please advise.
Thanks. My system info is below.
Latest after update D5 v.1.6.0.0218 Found the same problem
[image]
does your regedit solution not work on the update?
After the update of D5 Ver.1.6.0.0218 Found the same problem
[image] :ร้องไห้:ร้องไห้:ร้องไห้:
i used your solution and finally have something rendered. Thanks for your help. ![]()
even after the update
I congratulate you But right now I still have problems. Hahahahahaha
whats happening with your problem
Problem solved, Thank you much
i Still running the same problem on rtx 2070, i crashed while rendering on 98%.
tried to solve the issues using the solution above but none of it works, anyone got solution?
Hello kelvinandrean, their solution is related to the video driver, did you meet the same error message? If yes, please upgrade your video driver to the latest 496.13, then see the result:
NVIDIA DRIVERS GeForce Game Ready Driver WHQL
If the problem remains, feel free to know me know. And is there an error message before crashing? We may need logs to analyze this issue if it still crashes.
it works! thanks a lot
