D5 crashes when trying to open a project or trying to import a model
"I have this problem: When I try to open a project, it crashes/closes before loading 20%. Then, when I open it and try to import a model, the program automatically closes before I can place it.
My specs:
AMD Ryzen 7 5700x
AMD Radeon RX 7600
32gb RAM
The video:
https://www.mediafire.com/file/uvds8sda1qx2vy8/2025-11-28_15-27-30.mp4/file
Hi @chavez.135593
We apologize for the inconvenience. AMD-related compatibility problems have been a hot issue lately, and our team is still actively monitoring and investigating the situation. For now, the most reliable workaround is to roll back your AMD driver to the previous stable version, as the newest driver is known to cause loading failures, crashes, and usability issues in D5 Render 2.11.
This solution has worked for most affected users. You may refer to our official forum post for the full workaround and the correct driver version to install: [Hot Issue] After updating to the AMD driver (25.10.1), D5 crashes or becomes unusable
Once the driver is rolled back, your 2.11 models should open normally. Please let us know if the issue persists.
