I’m trying to open a D5 file and it crashes after 11% loading. It only happens with this file, which is not a big one. For the rest of the files it does okay.
Is there any way to open a backup file without having to open the original one?
I have access to a copy of the file that I saved 2 days ago and this older version of the file is ok, but when I save the file as a copy with another name, the new file is unable to be opened. It’s wierd… hope you can find a solution for this
1.Create a new file. Place some basic models of d5 asset in it. Save that project.
After save. Merge it with your otherproject that you cannot open.
1 time is was for me that i used to much caustic.
Another time it was a bug. The second time i merged a smaller old project. Basic model asset was not enough te remove the bug. - a bug haooens i every software -
You can also with merging select to not merge the lights or an antoher category.
