Custom Path - move path points issue on heavy scenes
Custom Path - move path points issue on heavy scenes. It works fine on light scenes.
PT_2.zip (2.8 MB)
Hi @Smolak
Tested it on a 1.0 GB Demo File - Terrain; no replication on my end, so I’m not sure how heavy these files should be in order to replicate the issue that you have mentioned.
  • Link: Unique Download Link | WeTransfer
  • I did notice on your screen-recording that the object will have a different direction since the pointer was not dragged, but rather it was clicking on another surface and had extended the path slightly.
    *If possible, please share the file you tested with us. If you’re unable to do that, could you let us know the size of the file you were using? This will help us investigate the correlation between larger files and the custom path tool.
When I removed all other scene objects my custom path fences started to works fine. So there must be something that collide with them. I will check if I can compress this scene to reasonable size.
Also as you see in my video this is near impossible to drag last point without creating the new - these dragging points collides.
I noticed on your video that you move last point without dragging it - how you do that ?
fenc (2).zip (670.2 KB)
UPDATE :
This is not related to scene complexity. I just have problem to drag last point because the new is created just over it and I can’t drag last one. I must deselect all ( right mouse button ) and after that start to drag last one. It is little more noticeable on complex scene because interface works little slowly.
Last path point has the same size that the new - there is no way to drag last point without deselect all.
fenc2 (2).zip (3.4 MB)
Hi @Smolak
I am actually dragging these points to a different location to edit the path. I’ve just realized that I have a habit of pressing the Esc key each time, which may explain why I wasn’t able to replicate the issue earlier.
  • Without pressing the Esc key, the path behaves as you described.
  • Therefore, if you deselect it first and then move it, the behavior is normal; the same applies if you press the Esc key.
Indeed, it’s quite troublesome if you haven’t deselected it first. We’ll improve this further, but for now, I suggest pressing the “Esc” key whenever your cursor shows the circle icon while dragging the path.
