Custom Path Issues - Camera Jump & Invisible Models
https://drive.google.com/drive/folders/1DRsM37B7XLghesKDmBtggzrPj7CjC1tw?usp=sharingIssue Description:
I’m experiencing two issues when using the Custom Path tool.
  1. Camera jumps to the model when editing a Custom Path
    When editing an existing Custom Path, the camera suddenly jumps very close to the model, making it impossible to determine where the path is located or accurately edit the path points.
  2. Model disappears after assigning a Custom Path
    Sometimes the model does not appear after assigning a Custom Path, regardless of whether the path is very short or very long. The path exists, but the asset is invisible in the viewport.
These issues make the Custom Path feature very difficult to use.
Videos Description:
Please check the video below for both issues
Could you please confirm whether these are known issues or bugs? If there is a workaround or if they will be fixed in a future update, I would appreciate your guidance.
Thank you.
Hi @ng0ccan0409
Thanks for pointing this out.
  1. I am able to replicate the issue regarding the model from the custom path going up when it’s redirected towards the 3d Model present in D5.
  • We will be investigating this further and will be working on a fix as soon as possible.
  1. As for the second issue, please try to modify the density since the model will not appear if you place the path first then add the assets after.
