Current Scene
Love the new update.
One little glitch is that if I go to a scene and zoom and pan out the current scene is no longer grayed out a bit like before the update which requires remembering what scene you were in. It would be better if it indicates the scene from which you’re panning around in is continually indicated when zooming and panning around.
Hi mate, it is by design. Now the Camera and Scene are separate, as each scene has its own camera by default.
From the top bar you can check which scene is selected. And if you want to keep a scene activated after moving the viewport, you can select its camera or activate it.
Our product team will take it into consideration, thanks~
Thanks Oliver. It will also show the current scene on the camera pull down but as soon as you zoom or pan it vanishes and there’s no indication of the scene you’re working in the scene list on the sidebar. Would be good if the current scene name remained static.
