Crashing
2.5.0.0310 :
RTX A4500
536.45:
Just started getting crashes on any save attempt or material change:
Been working successfully with a model and now it crashes anytime I try to change anything and save.
Help!
Upgraded to current version…same issue, immediate crash when changing a material
Was able to save a new version of the project, but when I try to apply a new material to anything it crashes
[Edit] I deleted a few imported objects and was able to apply materials and save. Not sure how they broke the project…Running an animation now, so I hope this is resolved.
Hi, you can check if your windows system is above win 10 21H2. And keep an eye on the dedicated GPU memory usage while running, if it’s more than 80%, it may cause a crash!
Hi:
I am not sure on the WIndows build. I see in system information that the Version is “10.0.19044 Build 19044” WIndows 10 Enterprise.
I did have another crash this morning when I was working on the laptop through external monitors. I opened up my laptop top and D5 crashed.
Scott
Hi!
What’s your driver version? You could check it on welcome page of D5 Render.
If your windows version is 10.0.19044, while your driver version is above 531.14, D5 will probably crash.
Therefore, I recommend you try to update your windows version.
Leah
I will check at the next opportunity.
thanks
Scott
