Hi everybody,
I just bought the Pro version to make some videos but unfortunately after launching the video I get this error. I have also tried it on another computer with an RTX 2070 and it keeps giving me the same error. I still use D 1.6.0.0218, but I also tried with the new version and the result doesn’t change. The video lasts about two minutes and is calculated at 1080p. I also noticed a big slowdown of others applications when I work with D5 or when it is computing a video. Is it normal that I can’t work with the computer when d5 is calculating? You can help me, strangely everything was fine before the purchase.
Tks
Hi, if you still meet this issue in the latest version please try the following methods.
Method 1: Run D5 as an administrator
Method 2: Set a virtual memory in the C disk, the steps are as follows: https://www.x-plane.com/kb/increasing-virtual-memory-on-windows/(recommended to set the initial size of 1024MB)
Thanks now it works. However, can I suggest to give the possibility to render only a certain part of the frames and to allow to create more different video sequences. I created a 2 min video and now I have to recalculate everything for an error in a 10 sec sequence.
Thanks again
