Hi, I’m very thankful for you checking my file, but I’m afraid it’s not the case. you see, 3070ti is well above recommended spec for D5 render and this scene only have 17mil faces, and I easily rendered 2 minute 2k 60frame video out of a 60mil face scene, which the scene doesn’t even open anymore. also, as I have mentioned before, I have another setup with RTX 3050, also 8GB which I tested and managed to render the same scene with ease.
the thing is, at some point, something happened to my D5 render in my 3070ti setup, which caused D5 to fail. right now, it struggles to open files without crashing. and that is very scary, because it was working good before. I know I’m going to do a clean install of windows, but as I try to teach D5 in my region, I really need to know how to solve this without reinstalling windows, not everyone can do that over a night. specially when it happens with heavy projects on due date.
the first time the problem happened, as I said, it was simple exterior scene, and it only was less than 10 frame overall, the scene only had a small rhino file and the usual D5 street assets. it was surprising.
the first time D5 crashed, was when I downloaded a scene from D5 video youtube, where it teaches how to bring scene from 3dsmax to D5.
after that, I had problem installing Rhino 8 on my pc so as a solution I decided maybe D5 doesn’t let it to install, and I uninstalled it, and then reinstalled it. maybe that caused some registry problems.
right now, it struggles to open files, and rendering seems impossible.
