Corona material will not sync with D5 Render
Hi There,
I make a scene in 3Ds max, with HDRI , Cameras, Lighting and materials in Corona, It is ready to render in 3Ds Max. But when I sync it in D5 Render, D5 Render did not show any textures, and even HDRI, and I have to make the textures from scratch again. What is the problem ? Could you please help me by that? Since it does not make sense to me
Thank you very much in advance for you help!
Hi @archviztech3d,
What version of Corona are you using? Are you using the latest 3ds Max LiveSync 1.0.0.0056 and D5 2.6 version? Did it used to import normally before? Can other materials be imported into D5 normally, only the Corona materials are missing?
If it’s convenient, can you send the scene file (The entire folder where the .drs file is located + modelling file) and your logs to support@d5techs.com? You can refer to this post to learn how to collect logs: D5 Support Tool Please attach link to the post, we will check it as soon as possible.
