D5 Render Version: 2.3.4.0931
Graphics Card: RTX 3090
Driver Version: 517.48
Issue Description: I moved my .drs file from my computer to my network, now I need to work on it again so I copied it back to my computer and it won’t open, loads until 9% then gets stuck. I am working in SketchUp and using the D5 extension to attempt to open the .drs file
Hi mate, the single .drs file cannot open the file because it is not enough.
A project folder is the whole folder which is saved by D5 Render, including the .drs file.
Please check whether your project folder is still on your computer, it normally has these kind of files:
Yep, that was the issue. I wonder if there are any plans in the future to put everything into one easy to transfer file? I do a lot of work in Lumion and they used to do it this way also, with many files and folders to transfer back and forth but now you inly need to move the one file. Anyway, thanks for your help!
You are welcome. Yes, in future we may support compressing all the assets files and other archives into one single file. It may need some time to develop, thanks!
