Hello D5 team.
I have pc with spec: i7 11700, rtx 3070 and laptop with spec: i7 11800h, rtx 3060.
Every time i start D5, cooling fan very loud even with blank file in both pc and laptop. I have checked task manager, gpu only around at 60-70 degree but fan make noise very loud. To compare, with other render softwares use gpu, I never hear my cooling fan loud like this even with very heavy file.
Is this normal with D5?
Sorry for my bad english.
Hello, it is not normal with D5. The cooling fan is often controlled by some other software like Game boost or your computer’s BIOS, do you have any settings like “high performance mode” on your pc?
Thank you Oliver for your reply.
Both my pc and lap set at balance mode. Can you tell me which setting I can do in Bios or game boost?
Hello, sorry that I cannot check the detailed settings of your computer, normally we can just set default settings and it will be ok. If the cooling fan’s very loud, the speed may be very high?
You may turn on Air conditioner then try again, I know it sounds ridiculous
but it sometimes can solve this kind of problem.
Thank you for your suggest Oliver. I will try dig some more. Hope can find solution for this.
Btw, you guys made a excellent job with D5. I really like output of D5 render. Keep it up guys.
