Bonjour,
Le tissus des chaises vert devient bleu quand ils se refletent dans le miroir. Je n’ai pas d’éclairage naturel mais que des spots, c’est une scene de nuit. D’ou vient le probleme ?
Apologies for the inconvenience. To further understand, could you please confirm the following:
What is the color temperature or color tint of your spotlights?
Does the color shift still occur if you warm the spotlight temperature or add a very low-intensity neutral ambient/HDRI light?
What are the mirror material settings (roughness, metallic, reflection quality)? Is it a perfectly sharp mirror?
Does this happen only in the final render, or also in the real-time viewport?
Also, could you please share a screenshot or a short screen recording showing the issue? This will help us better understand the lighting and material setup and provide more accurate suggestions. Thanks in advance
