After clicking “export”, I choose a folder to save, but after the render there is nothing there, what should I do?
Hi there,
Thank you for your feedback.
Please try to save under English path, to see if the issue can be solved.
hi jessie,i have same issue,what do you mean ‘under english path’? can you explain more?
I solved this problem myself, really need to specify the path to specify in Latin, if the user name is not in English then these problems may occur. “C:\Users\User\AppData\Roaming\D5 Render” this is how it should be
