Cannot select materials/brushes from other worksets
When using the worksets feature, we’ve noticed we cannot select materials from objects on other worksets. You must either be in the cenrtal file or copy it to your assets while in that workset first. I understand why you cannot edit the material for an object in another workset, but we should at least be able to copy it or add it to our assets. It’s been a real pain when collaborating since we have a lot of materials that are not always saved to the assets first.
This also applies to vegetation brushes. I would like to copy the same vegetation brush from an object on another workset but that is restricted as well.
Please allow the ability to at least copy the materials and brushes, thanks.
D5 Render Version: 3.0.1
Graphics Card: RTX 5090
Driver Version: 591.74
Issue Description: Cannot select materials from other worksets
Hi @joseph.lico
Thank you for the feedback. You’re correct that materials and vegetation brushes from other worksets can’t currently be selected or copied because D5 Render treats models outside the active workset as read-only.
If you’d like this feature considered for future updates, you can post it in the Ideas & Requests section of our forum so the community can vote and the team can track it.
