Can someone please remove the vines from my scene
**D5 Render Version:2.9.1.0509
**Graphics Card:3060
**Driver Version:566.14
**Issue Description:
My work keeps stalling because the vines I’ve placed inside the project make the file unopenable every time. I couldn’t find a solution to the problem either. All the adjustments I made for hours went to waste. Can someone please delete the vines inside?
Upon opening, an error pops up after a few seconds saying,
“Out of video memory trying to allocate a rendering resource. Make sure your video card has the minimum required memory, try lowering the resolution and/or closing other applications that are running. Exiting… ” The file is unworkable.
The file I’m working on: D5 VINE - Google Drive
Hi there,
I apologize for the inconvenience. You can delete the f2 folder where the pak files are located to open the file and then delete the vine assets. Please do not update the assets unless you have already deleted the Vine assets. Let me know if this helps, thank you.
It worked, thank you very much
