Can I run D5 on the laptop I want to buy?
Hallo
I am about to make an investment in order to use D5 Render. Therefore I would like to make sure it meets the requirements. Hopefully they even exceeds the minimum requirements?
Specifications:
Legion Pro 5
Ryzen 7 6800H
RTX 3070 150W
32GB 4800mhz RAM with low latency timings of CL34
4TB SN850X Gen4
Thank you in advance for your help
This should run D5 moderately well. Not the fastest but can render good quality. You should just keep in mind that laptop overheating and battery life should be monitored when running heavy applications, especially when rendering.
Hello!
Does D5 Render support RTX 4060 Ti 16GB graphic card? I saw in list just RTX 4060 with 8 GB.
It does. Just keep in mind the same factors about battery life and overheating/cooling if using a laptop.
