Version 2.6.1
laptop 3080
When re-rendering scene it changes the view slightly up from the original. This happened to 3 out of 35 renderings. It has also happened on other projects. This makes post-processing changes very difficult as I have to start over or pull the image down in photoshop then crop the top.
Did you have the shift issue after opening the same scene using a different computer? Did you render each image individually or did you use a queue render when rendering? I would suggest sending us this scene if possible.
Using the same computer and all same settings. I tried both queue rendering and individual
Hi, are there both two-point perspective and perspective view images in the same queue? This could possibly cause an offset. This is a bug and we are fixing it.
