Camera changes position when selecting scene
I create a scene and then go into the ‘Image’ mode to export. In this section, I set the aspect ratio, size etc. I then click ‘update scene’ to save these settings. But if I click another scene and then click back to the new scene, the camera position is slightly different.
This is a huge frustration, as all my layers in photoshop file are useless, and I have to start the editing all over again.
Others have complained about his issue. When is it getting fixed?
hi, can u share camera original scene and shifted camera scene.
Yes…I have the same problem…since D5 2.6…and yes this is frustrating.
Sorry for this.
Can you tell me which version of D5 you have used? If possible, could you show a screenshot of this problem? Also, do you have two-point perspective turned on?
Sorry for this, we are trying to find what caused this issue. Can you tell me which version of D5 you have used? If possible, could you show a screenshot of this problem?
I have version 2.6.1.0401. I will send a screenshot when it happens again. Today I’ve had no issues. It’s happened a few times in the past, but I can’t seem to figure out how to recreate it. Sorry.
Really thanks for feedback, we will check this.
I have the same issue, is there any solution already for this? thank you
Hi @ayessa13.ad Could you please share some more details regarding your experience? If possible, share the rendered images with different positions and the scene file as well. Kindly collect your logs and send them all to us at support@d5.techs.com.
Sorry for the inconvenience.
To collect logs, please refer to; D5 Support Tool - Get Help / Tech Support - D5 RENDER FORUM
