Brushed landscape
It seems when I use the brush tool to apply plants they are “attached” to my imported model.
So I cannot remove the model and replace it with another model but still have the same landscape?
After I have “painted” 3D models of plants. How do I come back later and change parameters or delete them? How do I find what plants I used?
Is this correct?
If I need to change the landscaping, I need to re-import my model, apply textures again and then create a new landscape.
Am I missing something here?
Ok, I can find the brushed plants in the recent folder. But I cannot adjust parameters after brushing. Correct?
Brushed plants attached to my imported model seems strange. Why is this the way you do it? Please.
I didn’t realize that brushed plants attach to the imported model. Now I understand why I could not erase them.
After unlocking the imported model I realized I could erase them BUT if I erased too many, the UNDO command would not put them back.
Is this correct?
hello, to remove those painted plants you need to use Eraser (near to the brush). It will erase all types if you do not select specific models for it.
Vegetation Tool - User Manual (d5render.com)
In the next version we will have some new features, and you will be able to select those plants after they are painted.
I have noticed that if I erase too much I can’t use the UNDO button. Is this being fixed?
Hello, this is currently a feature limitation, we did not add the feature to undo/redo paint/scatter operation.
In the next version we will support:
Know what plants you painted and delete them.
In 2.3 version we will support UNDO/REDO.
Re-import model and apply same painted,ok,im thinking about this,maybe we can do it.
What we will support in the future but not this time:
1.Adjust parameters.
2.Replace plants.
Thk u for you suggestion :partying_face:
