Hi there,
Could you please send me the scene file, including drs, model and asset, to my email - minjia.huang@d5techs.com
Thank you very much
Hi there,
Thank you very much
Hi there,
Thank you very much
@Jessie_Huang Thanks. Im using your sample Scene EXTERIOR BY YOGA4ARCH.
I am trying to use the brush in other scenes and it seems to work.
I confirm shortly.
SEPARATE COMMENT
Now I have another problem with an interior, a ghost spot light appeared, which is not in the scene and I cannot remove it.
Hi Franco,
Thank you for your reply.
1 - ok we’re checking it now.
2 - It’s known and we have already fixed it. Please make sure you have updated to the latest version, whose version number is 1.6.1.0228
May I have the screenshot of this issue?
May I have this scene file, including drs, model and asset?
My email is - minjia.huang@d5techs.com
thank you in advance
Yes of course, now I send you.
Hi Franco,
We’re still checking the issue and finding out the reason. Meanwhile we’ve deleted the spot light manually for you, in case you need to use the scene now.
I’m sending the link via email to me. Please kindly check it out.
Thank you very much
That’s happening in all files I have. Not just in one. So I don’t think that sending you the file will help anyway.
Same here!
Please update to the latest version and try again.
The brush works very well now.
One suggestion we need numbers on the slidders to utilize control on the size of the asset.
Yeap, now it happens only to the smooth mode when you render it, we are fixing it. If you find the problem still persists after switching to precise mode, please tell us, sorry for the inconvenience.
Hello! My scatter tool does not work too. D5 is up to date too.What can I do?
Hello, @i.sonmezkan
Welcome to D5 forum. I apologize for running into this issue. Is this the first time you’ve encountered this problem and are using the scatter tool? Is the issue occurring with all your files or only with a specific file? Are you opening an older version of your project or an archive project? What modeling software you are currently using and what is its version? To learn more about your current situation, could you please share more details about this problem or photos and screenshots?
Thanks
