Brush density
**D5 Render Version: 2.8.0.0469
**Graphics Card: 3060
Driver Version:
Issue Description:
Brush density is way too high on setting close to zero.
in the screenshot it was just one click with this brush settings.
Please note the radius setting of your brush. Setting the radius to maximum will activate the fill tool.
i want to use the fill tool.
i had the density slider close to “zero”, but with only one click there were far to many of the selected plants.
the density slider seems to work fine with ornamental grass but not so well with other plants.
Hello. Do you have a comparative images of the effect of these two different types of plants using the fill tool?
I tested this and there does seem to be some difference between the different plants, but on my end, the difference isn’t very big.
you’re right. density is the nearly the same for different types of plants, BUT …
the problem persists that the density of the brush tool is way too high for the left side of the slider. even when set density slider to “zero”, there are several plants on one m2.
Thanks for reporting this. We may improve this in the future.
when i have saved brush presets, how can i load or apply them to the brush tool?
