I would like to know if anyone knows how to make boucle fabric in D5 RENDER? Like the one below.
Hello Studioimage3m
I saw what you posted, being in D5 there is no map texture of the Bouclè, I tried to do it myself to give you a hand, I have the right texture which is this:
Then with a small BPR program I obtained the other textures:
I took an object from SketchUp an armchair and I made the material, these are the results:
I hope the quality satisfies you, and it helps you
PS: I’ll insert the image how the material should be set
Thank you very much riccardofortelli it was very good it will help me a lot, thank you very much
