Hola, he tratado de abrir un archivo de D5 y se queda cargando en 81%, antes podía abrirlo sin problema.
He intentado abrir un archivo diferente y ese si ha abierto, que podría hacer para volver a abrir el archivo? Muchas gracias
Versión D5 2.6
NVIDIA GeForce RTX 3060 / Drivers version 551.52
hi, is the currently opened file a local path file or a network path file? Is the file saved successfully after previous successful opening?
And try opening a historical version of the scenario and see if it works?
Does it mean opening two D5 scenes at the same time? This is not supported yet.
In general, to open a D5 scene, there are two main ways: open the scene directly or open a historical version of the scene.
Hi, I tried to open a historical version and the problem remains, it stops loading at 81%.
I have the file on my laptop, it’s not online, is this the information you need? Thanks
