Archicad to D5 windows and doors?
I build my project in Archicad and export it to D5, and everything used to work perfectly. But recently, when I export a project from Archicad to D5 and open the file, everything looks fine except the windows, doors, and pictures are missing.
I haven’t changed any settings, and when I open old projects, I can still see the doors, windows, and images. This only happens with new projects.
If I select the doors and windows individually in Archicad and export them to D5, they appear, and I can add them to the project as separate elements. However, the images appear as one unified material for all pictures, not as separate individual images.
What is the problem? I can’t understand what’s happening.
Hi @archalaa1
Can you please share to us a video-recording showing the whole issue?
  • Some Archicad export or sync workflows have a setting (or a change in default behavior) that filters out certain element types during a full-model export unless they are explicitly selected. Since your individual selection exports work, this is the #1 suspect.
