Just update the new plugin 0.2.0 usa in a AC24 INT and it doesn’t seems to work. The tabs : Sync, View On, View Off are grey out.
I tried to export a .d5a file and open it, but there is no model in the preview.
The previous plugin (0.1.3usa) was working fine.
Setup:
WIN10, ASUS 2070 8GB, D5 1.7.1, Archicad 24 INT,
You need to launch D5 from the plugin, which will active the tabs and work normally.
Thank you
Thanks for the answer but i am not following… What do you mean “launch D5 from the plugin”?
What i do is open D5>new>empty scene and then start AC>3d model tab but the D5 plugin is still grey out.
Click triangle to launch D5
Please kindly refer to 登录 · 语雀
Thank you very much for your reply.
I had to modify my D5 menu in AC in order to see the triangle (and the other new options). Now everything works fine.
Thank you.
