I have an issue with Alembic file imported into D5 render but unable to apply textures. Please help me out in this regard
Thanks
SV
Thanks
SV
Hi, what program do you use for Alembic, perhaps the problem depends on this, I’ll give you a tutorial to help you understand how to solve it.
Currently, .abc format files with material maps are not supported to be imported into D5. You need to distinguish the material in the modelling software and re-add the material after importing into D5. We will consider support for this in subsequent iterations. D5 2.6 supports fbx with material import, but it doesn’t support importing complex material nodes for the moment. In this case, it is recommended to use a format that D5 supports direct reading, or use a D5 converter to import the model into D5.
